meant to type guiderails.dificult to tell from that angle bob, certainly the side looks true enough, but picture doesnt show from other angle.
most likely as someone else suggested that the drawers are put together wrong or its the guiderals, no probs to check and fix.
sorry - front end not 'from'Had a similar problem with some drawers in the house. Almost certainly the from end of one (or both) of the drawer runners has come loose - just tighten the screws on the front end or re-drill them if the original hole has become oversized - use a longer screw if this is the case.
You win the prize. Two weeks in Tenby - bring some toolsI bet thats a bailey !!!!!!!!
Caravan Medic due on the 28th of this month.dificult to tell from that angle bob, certainly the side looks true enough, but picture doesnt show from other angle.
I can think of no answer that would'nt offendMy missus has warped drawers. I told her it's the washing powder she uses.
The clue is laminates warp in a damp environment.Yes they look twisted out of shape.
Hope you don't want me to check them with my feeler gauges,
Is that for the built in ventilation 😱)
Thanks for the tip. I have checked all the obvious runners rails but its down to the draw front laminates warping.Had a similar problem with some drawers in the house. Almost certainly the from end of one (or both) of the drawer runners has come loose - just tighten the screws on the front end or re-drill them if the original hole has become oversized - use a longer screw if this is the case.
Thanks PatI would check the level of the unit. It may be slightly higher at the back.
Both draws have gone like this over the past two months, in fact there is nothing in the draws, I'm hoping the engineer will just order two new draw fronts and that will resolve the issue for this year.Looks like the other side is square?
As the bottom drawer is also the same i would say it the drawer runner this side i would re adjust them slightly lower at the back.The side that they are attatched too seems to have raised at the back.
