Truma Gas Regulator Type EN 61-DS - Dangerous Leak
Aug 31, 2007
I write to make you aware of a potential disaster concerning this regulator fitted to my new Elddis Odyssey 544 caravan.
On setting up the caravan on the first stop of my holiday in August this year I opened the front locker and turned on the gas. After a while I noticed a smell of gas. After some time and by using a washing up liquid solution as a leak test I eventually traced the leak to the small yellow button on the left side of the regulator.
I cannot stress how dangerous this was and how lucky I was as prior to smelling the gas and after turning the gas on I used a cordless drill to operate the corner steadies. I do not want to think of what might have happened if I had operated the drill in proximity of the escaping gas.
There was no literature concerning the regulator with the caravan documents therefore I had no option but to purchase and fit a replacement purchased from a local dealer.
So far so good but can you imagine my concern when on reading the literature I discovered that the leak would appear to be designed in as a Pressure Relief Valve. Luckily I have a sense of smell or this leak would have gone undetected with possible fatal results.
I fail to see how this can be acceptable surely if there is a malfunction the device should be able to shut down the gas and not simply vent gas to the atmosphere.
I really am concerned that this is a disaster waiting to happen and feel as a matter of urgency that these circumstances be broadcast as widely as possible.
936
Ralph, whilst what happened is a concern, the regulator has to have a safety device, which either malfunctioned, or did its job.
At least it did not allow bottle pressure to damage the internal pipework.
As for the regulator itself, it is still under warranty and as long as you produce the old reg and receipts for the new one, and fitting, your supplying dealer should reimburse you the costs.
I would also contact Truma Technical department and ask their view on what happened and if they know of any similar reported problems.
You can email them at;
Contact Truma UK
Postal Address:
Truma UK Ltd
Park Lane
Dove Valley Park
South Derbyshire
DE65 5BG
England
E-mail:
technical@trumauk.com
