Hi John Google Truma and go to movers
You are here > Products > Caravan Movers > New Generation Mover TE
Unique for double-axle caravans - convenient manoeuvring with pin point accuracy at the push of a button.
For all double-axle caravans and trailers weighing up to 2,250 kg. Equipped with 'Smooth Start' drive and electric swivelling mechanism for additional convenience.
Drive rollers are swivelled in and out electrically at the push of a button
Light aluminium rollers protect the tyres
'Smooth Start' drive for jerk-free starting and stopping
Weighs just 33 kg - up to 50 % lighter than comparable manoeuvring systems
Safe, convenient handling using an ergonomically designed radio remote control
The new controller transmits and receives at 868 MHz, providing an extremely stable radio connection
Reliable hold on slopes (25 % with 1,200 kg)
When driving around corners the outer motor runs continuously and the inner motor pulsates, reducing tyre wear
No low-lying parts - provides the best possible ground clearance
The motors are positioned immediately before or behind the axle
All Mover components are protected against water spray and corrosion
A powerful drive allows the caravan to be reliably manoeuvred, even on difficult terrain
Simple 12 V electrical installation
Shorter rollers prevent the need for side apron adjustments
Remote control action
Even more safety:
A 13-pin safety socket that is included in the scope of delivery prevents the Mover TE from being unintentionally engaged, for example while driving
General operating permit (ABE) means that no TUV acceptance is required!
Convenient installation:
The Mover TE is suitable for almost any double-axle chassis and is easy to fit - without drilling or welding the chassis. The ABE provides you with 100% safety.
The original accessories from Truma include individual installation kits for the different chassis types.
