Hi Len
i had same problem, if you have drawers above the fire take them out to gain access to rear of fire, its pretty dark but if you put your hand right down behind the fire you will feel a plastic control box, it feels like its on the floor of the van, on the left hand side of the box there is a small jack socket on the side of the box its a bit fidelly but with some determination you will feel it with your fingers. the instruction i had says you should route the cable around the back of the fire and bring sensor out of the right hand side but the cable is not long enough so routed it through the left hand side next to the heating ducts and fastened to the gas therostat, i have to say i notice quite a difference, i find the van gets way to hot now where as before it would go cold at night, hope this helps Len.
