- Feb 13, 2002
- 19
- 0
- 0
So away over Easter in our super duper new Swift 645 we suffer a problem. Very frosty outside and a little chilly inside. Yes the age old problem of the heater cutting out after a while and taking an age to come back on again.
Picture this. Swift with all their years of making caravans have still not yet worked out that the remote sensor needs to be somewhere other than where it is fitted in our 645. That is to say not directly above the fire and about 6ins to the right of the fitted car radio. So the fire lets out hot air which rises to the remote sensor and off it goes. Or even if the fire is turned down low, play the radio which gets quite warm and off it goes.
Management gets very excited. Michael rings dealer who tells us that if I reach in and unplug remote sencor then fire goes back to normal operation. So I unplug sensor and then what, the fire still cuts out, why ?
Well apparently if you unplug the remote sensor then the original thermostat which is in the rotary control comes back into operation. And where is this rotarty control, yes of course diectly above the fire. Ahhhhhhhhhhhhhhhhhhhhhhhh !!!
We switch to Gas operation and stay warm. But I need a fix, because I'm a stubon old git, so when we get home much thought goes into the new location of the remote sensor. I fit it to a long lead and experiment around the caravan, with little success. So a different solution is called for.
I've measured the thermistor they use as a thermostat and find that in the fridge it measures 25k ohms and in the sun 8k ohms. Answer one 25k, half watt resistor soldered across the terminals of a 3.5mm jack plug. The remote is now unplugged and the thermostat in the rotary knob is kept off line by my new gizmo. But of course there is no remote control, if it is too warm or cold you have to get off of your backend and turn it up or down.
An answer or what, cost 97p. Have I done something realy naughty. Polite answers only please
Regards SuperMike
Regards SuperMike
