- Feb 17, 2008
- 20
- 0
- 0
We have been having problems this weekend with the Truma Ultraheat thermostat, in that it was not kicking in until the temperature was set around the 7-8 mark so we had either full whack heat or none at all (we're too tight to use gas
I have a suspicion that heat from the fridge is effecting the sensor in the control dial as it is positioned in a panel/channel directly above it. Has anyone had a similar problem and is it considered a awarranty/design issue?
Would installing the plug in remote thermostat solve the problem (by overriding the existing thermostat) and does this still allow the temperature setting to be controled from the existing dial on the control panel?
Thanks in advance.
Thanks in advance.
