I have a Lunar Ultima 524, with a Truma Ultraflow water system.
It's working fine generally, but there seems to be a problem with the pressure switch mounted under the bed-box.
When the pump is being used with the battery charger switched off, alll is fine. Once the charger is turned n however, once a tap is turned off the pressure switch "clicks" loudly for 3 - 8 seconds, and the 12v lights in the van flicker in sync.
Anyone had any experience of this?
Thanks,
Lee.
Thanks,
Lee.
