Truma Ultrastor mystery
Aug 17, 2008
236
First of all I replaced the element in this about a year ago as the old one - looked like the original had gone open circuit, not surprising when I got it out, real corrosion! Anyway all well until this weekend. Worked fine on Friday night, red hot water as usual but on Saturday it was cold? Tried the gas instead and all fine again. When I got home this afternoon I checked it all out. Mains getting to the element and the element shows around 120 ohms so not open circuit. Left it on for a while and I have hot water again? Anyone else know these to simply cut out and then work again?
937
Yep, it is probably the upper temp limit sensor starting to fail.
Aug 17, 2008
236
I've checked the wiring again tonight and I don't see anything which could switch the element off? It's wired directly from the switch,
through a small box with some 'chockblock' and then straight to the element so once the switch is on then there is
240V going to the element.
Jul 15, 2008
3,902
1,088
.....this is a very good company for spare parts. They also have dowloadable parts diagrams.
The water heaters as Damian says are fitted with temperature sensing devices that can switch off the element and may be faulty.
http://goo.gl/eVYdW
4,343
Hello Len,
I am slightly puzzled by your opening post:
"Worked fine on Friday night, red hot water as usual but on Saturday it was cold? Tried the gas instead and all fine again. "
Do you mean it failed on site to work on mains, so you switched to gas and it heated up, then you switched back to mains and it continued to work on mains satisfactorily?
Or do you mean you switched to gas and left it on gas which worked ok?
I note you did try it successfully on mains when you got home.and
You then ask:
"Anyone else know these to simply cut out and then work again?"
Intermittent operation such as you describe in most appliances is usually down to faulty switches.
Another possibility which I have encountered in heating elements is where the element is intermittent due to expansion and contraction around a fracture in the element.
You don't tell us how old your heater is, and I know there have been some revisions in recent years, but up until 1999 the Trumastore /Ultrastore heating elements had a built in thermostat switch. as far as I recall the switch cannot be changed independently of the element and vice versa.
Aug 17, 2008
236
OK sorry for confusion:) Situation was --
Arrived on site Friday evening, connected all up and switched hot water on - mains. As normal hot water within 30 mins.
Saturday morning went to draw hot water and it's gone cold so I switched to gas and it heated up again. Mains switch to element still lit fine. When we got back on Sunday I tried it again on mains after testing that the element had continuity (120ohms) and that mains power was getting to the element. Hot water once again! This element was replaced a little over a year ago as the original has corroded and gone open circuit. Just puzzled as to how it would just switch off and then start working again? As far as I can see there is nothing between the mains switch and the heater element itself to act as a cut off.
4,343
Hello Len,
I can assure you there must be some sort of thermostatic switch somewhere, the appliance would be unsafe without it. and it could not receive its CE approval without some means of automatic temperature (i.e thermostat and often and emergency over temperature device as well) control for all fuels.
Aug 17, 2008
236
I am led to believe that it's built into the element itself but I will double check all the wiring again. I believe I may have the original installation manual as well so I'll check that to see if there is a wiring diagram. Unless anyone else has one?
Aug 17, 2008
236
OK here is the wring from the installation manual. I don't see any cut out etc at all. Looks like it just relies on the heater element?
data:image/png;base64,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
937
If your element has only the mains lead going into the end of the element then th ecut out is located within the end of the element inside the sealed round end fitting and you have a 750w element.
If your element has a second yellow cable coming from the end to a small white sensor then the cut out is the small sensor and is an itegral non interchangable part of the element and its a 850w element.
And thats the difference between guessing what may be and knowing what is.
Aug 17, 2008
236
Actually it's a 450W element as clearly marked both on the heater and the element AND it only has 3 wires and they ALL go to a junction box which then feeds directly to the mains switch - as clearly shown in the diagram I posted.
I can only assume that the cut out/temp regulator is built into the element itself - not surprising as they cost £45-50 a time !!
937
Yep, my mistake meant 450w, not 750. The 450 is a straight element, the 850 is canted downwards to heat more water.
The cut out is in the end , not actually part of the element but attached to it inside the shiny resin end cap
The 3 wires are the standard Line, Neutral and Earth.
The diagram does not show up on the posting, only a red X in the corner of the box where it should be.
4,046
1,780
It does out here in the sticks, so its not a server or contributor problem, Len got it right.
937
I didnt say it was anyones fault, just it does not show on my screen,not that it matters.
Apr 7, 2008
4,909
I can see it on my phone ok.....
