I am afraid I must make a couple of observations on statements posted in previous posts.
First is " PLease bear in mind that as the Ultraheat is also a gas appliance it must serviced in accordance with the manufactures instructions but a competent fitter"
The Ultraheat is NOT a gas appliance, it is purely electrical and is a totally separate unit to the gas fire, albeit that it sits behind the fire and uses the same blown air system as the gas fire.
Second is " The Truma Ultraheat is intimately connected gas heater, and combines Gas, Mains Electricity and 12V energy systems."
Again the inference that the Ultraheat is a gas powered unit is totally wrong . It is a stand alone electric system which only has mains power connected to it.
The 12v operation of the thermostat is fed by a transformer on the Ultraheat PCB, which is totally separate from the main 12v systems.
However, as the unit sits behind the fire and normally needs the fire to be removed to gain access it is best left to a qualified engineer as not only is there gas connections but also exhaust seals to replace and test on refitting the fire.
