I suppose it depends on the aerial, my Status plus 550 aerial is not powered only the wall amplifier.The aerial has a built in amplifier and the power supply is normally inside the caravan. It is normally the built in amplifier in the aerial head that goes faulty according to posts I have read about the issue.
They did state that they using another aerial for signal so TV okay.Does your TV need retuning ?
I thought that the status aerial had a built in masthead amplifier? I am not familiar with the Svenson set up, but it is probably a power supply and splitter? To the best of my memory domestic set back amp/power supplies were not very reliable and most technicians avoided installing them.I suppose it depends on the aerial, my Status plus 550 aerial is not powered only the wall amplifier.
That is exactly how Status tells you to test the Aerial, in their operating instructions.Not sure about caravans systems however if you take the output feed from the aerial and use a back to back connector and coaxial lead to plug the lead into the TV, it is unlikely you will get a signal due to the masthead amplifier.
Get off it. No self respecting macho person reads operating instructions! LOL!That is exactly how Status tells you to test the Aerial, in their operating instructions.
No it works ok with mobile aeielDoes your TV need retuning ?
Needs investigating and fixing without too much delay.View attachment 7178what do you think ?
There is of course the possibility that originally both units were Status, but the perhaps the Svenson replaced a faulty power supply, but never cured the fault?It would help if the OP had said which make and model of caravan and aerial (even a picture of the aerial) would help.
The Svenson amp is IME most often supplied with a 'flying saucer' fixed omni-directional antenna. I am also curious why there are two co-ax cables going into the antenna shaft - only one is required.
In terms of amps. with Status aerials if the antenna has orange or red writing on it then the amp is inside the aerial and the inside box is purely a power supply to it. These antennae are old and now (thankfully) getting fewer and fewer. On the other hand if the writing is purple or blue the amp is in the box inside the caravan and the bit on the roof is just any aerial, nothing more.
Generally the omni Status 300 series will have an aerial with the amp inside it, whereas the 500 series is moveable and has the amp inside the van.
Totally useless aerial. Bite the bullet and get a proper status aerial installed. The aerial is so bad that dealers were replacing them at their own expense due to the high volume of complaints. There were a huge number of complaints on the Buccaneer groups about the aerial. If I remember correctly it was an Avtex twig aerial?Correct it's a whip ariel . The van is a 2015 eldiss rambler.
