- Nov 11, 2009
- 24,868
- 8,964
- 50,935
I don’t think many would be owners consider the cost of replacing an axle.See #3 . I said just that . My point was the large SA axles actually cost more that one TA axle. It’s all relative
Nor do I , surely if we thought a van would need a new axle, we would rapidly cross that off our lists.I don’t think many would be owners consider the cost of replacing an axle.
Just another potential cost factor .I have only ever come across SA owners with a collapsed axle😉I don’t think many would be owners consider the cost of replacing an axle.
Not sure its at all "obvious"; it will reflect the componentry and labour costs each involves, along with how the production integrates with a multitude of the company's established facilities.If a caravan has two axles, it is fairly obvious that it will cost more than the equivalent single axle?
In all the time we owned TAs, we never came across that restriction in the UK and also never had an issue in France or Spain. I think that the so called restriction is a total myth unless the site is not capable of handling a TA due to perhaps the entrance from the road.It was the restriction that quite a number of sites impose on 4 wheels that really made my decision.
So went for a single axle van, and have no regrets![]()
The number of axles on an HGV or it's trailer is generally determined by maximum axle limits which are imposed by highway authorities across EU/UK.Don't think TA are more stable when towing. Look at HGV,s with twin, triple axle, they are still prone to getting blown over. 😳
I don’t think the number of axles really has an effect on the likelihood of being blown over. Other than a TA may have a lower Center of Gravity but that’s not likely to be too significant as the roof is loaded with solar panels and a self finding satellite dish. 🙈Don't think TA are more stable when towing. Look at HGV,s with twin, triple axle, they are still prone to getting blown over. 😳
I treat warnings for "high-sided vehicles" as applying to caravans and reschedule or reroute - never tipped over yet!If the wind is strong enough to blow over a HGV/TA/SA surely you shouldn’t be out towing.
Have you ever driven a HGV?One can't compare HGV's with caravans anyway because artics carry a much larger proportion of their load on the rear axle of the tractor unit than the relatively low noseweight that the caravan exerts on the towcar.
