- Dec 6, 2007
- 414
- 0
- 0
Hi
i have an on-board tank / pump / accumuilator type water system.
It has two faults, 1. The pump will not run unless you by-passthe switch in the base of it. i've got it by-passed & we just use the master switch as/when we need water. Is there a common fault or easy fix to this? I think its a Sure-Flo pump , it got the switch in the base, a clear inlet housing & is mostly blue & dome shaped.
The second thing is I've pressed the car tyre valve on the accumuilator & no air came out! what pressure should this run at?
Any advice welcome
Gareth
Any advice welcome
Gareth
