tyre pressures
Jun 30, 2008
17
Anyone know what my tyre pressures should be ???
Its a single axle ( two wheeled ) Adria Optima 4 berth from about 1992 ???
Jan 31, 2008
282
Where a manufacturer's recommended tyre pressure is not available, this formula will allow you to calculate the approximate tyre pressure for your caravan.
(MTPLM Kg) x (Max tyre pressure in psi)/((Max tyre load Kg) x (Number of wheels)) = Running tyre pressure in psi
Example:
Single axle so 2 tyres
Max tyre press = 65psi (written on the tyre wall)
Max tyre load = 600Kg (written on the tyre wall)
MTPLM = 950 Kg (see plate on caravan chassis)
950kg x (65psi/(600kg x 2)) = 51.46psi
3,455
I'd just repeat the information given by Legsmania.
Given the age of the caravan I'd trust that method better than secondhand or anecdotal information.
3,455
What's the gross weight of the caravan?
The tyres will have the maximum load and maximum pressures moulded on the sidewall.
