hi
i have a steady leak of water coming out of ventilation pipe from my ultrastore water heater
can anyone help
can anyone help
hi damianThere is a pressure relief valve located in the fitting, which has failed.
You need a new fitting, repair is impossible.
thanks for advice i will try it out this weekend and let you know resultsHello Kevin,
No, you can breathe a sigh of relief.
You justneed the red elbow fitting, it is easy to replace, unscrew the old one, undo the water connection and vent pipe, fit the new one and reconnect the water pipes.
