under shelf tv mount
Dec 30, 2009
1,662
Sproket, where did you get your tv mount, looks good and tidy the tv area up nicely on our van.
Kevin
Apr 7, 2008
4,909
You have got to make it return to this page when they close the link :eek:)
like the one i do
Dec 30, 2009
1,662
Sproket, looking at that pic of screw type bolt thingy, will I have a wacking great hole in the base of my wall cabinet??
kevin
Apr 7, 2008
4,909
Kev what you do is drill four holes 8mm dia, so the threaded insert will fit in, you have to remove the spikes, the flat piece then sits over the hole, i used some araldite, when i did the final fix, i put it on the top of the inserts & on the metal plate so that if by any chance a screw came out, it would stay there, you will need four of those inserts with a 5mm thread, & four m5 x 30mm ( what ever you shelf thickness is ) counter sunk machine screws, so that the plate can rotate side to side when fixed.
Apr 7, 2008
4,909
Kev
Here is some more photos to explain a little better, you will notice the back plate is fixed to the tv, & i use two 5mm wing nut to hold it onto the mounting when on site.
Dec 30, 2009
1,662
Thats great, thanks for the extra pics, I understand now. in the first pic It looked huge.
Thanks again
Kev
