- Jul 15, 2008
- 3,874
- 1,049
- 20,935
………most caravaners are familiar with screws falling out and various bit and pieces working loose due to the rigors of towing their caravans.
Now my caravan is getting on in years but owned from new and I have always thought that the way the gas fire was secured was .......pathetic.
The fire sits on a rectangular hole cut in the caravan floor.
This floor like most caravans is a laminate of two outer pieces of thin plywood bonded to a much thicker layer of polystyrene.
The fire, which is relatively heavy, was fixed to the caravan floor with 3 self-tapping screws down one side of its rectangular baseplate.
The screws have always worked loose and are impossible to tighten.
The Unforeseen Consequences
Since the pipe was rigidly attached to the underside of the caravan and to the fire, the movement of the fire caused a metal fatigue fracture.
This problem was found because I do rigorous checks before and after every trip and in this instance I smelt gas when testing the system.
The fracture was not visible as it was in a union near an olive seal.
The leak has now been rectified and the fire is now bolted to the floor.
With hindsight I should have done this before or better still so should the makers of the caravan!
PS ……my caravan wheels are balanced.………the fire has been free to move around on its mountings during towing resulting in the cooper gas feed pipe breaking clean through causing gas to leak.
