URGENT HELP"Primus aquaflex" heating
hallo everyone! We have a Bessacarr Cameo 550gl 2001 and we are IN NEED for help with the heating system ( PRIMUS AQUAFLEX AB)
We need a gasket 150mmX3mm for the "gas ignition part". We found something that it may work but it cost over 400€.. does someone could give us some advise...?
We tried this special silicone to replace the gaskets ( supously holds 350°C), but doesn't work...the glycol still going trough the exhaust...
Any comment will be appreciated...thanks!
You trying to pass the buck again Damian!!
I've not touched a Primus since I discovered Bernard and he's retired!
He did tell me though he doesn't know of any gasket, certainly not that can't be made from standard sheet material?
That all leaves me wondering what this 150x3mm might have looked like? Is it round ie a silicone O ring or straight length of silicone cord?
Also what it's fitted to looks like? Any pictures please OP?
Gary, I know you are a super God as far as all things Carver are concerned, it is only because of you that so many Carver items are still able to be repaired.
Hope you and the family are well.😍
You've not lost the art at all have you! 😂
Yes though we are all well thanks, same to you and yours.
Feel free to ring if you like mate, can't seem to find the name your numbers under?!🙄
