I will pick up our Caravan in a couple of hours time and I am just going through all the checks etc that I thought I would need to look at. One has come to light that I need a quick check on.
Toyota Max Nose weight 100kg
Tow Bar Nose weight 130kg
Bessacarr Nose weigh 100kg The dealer who I just phoned said around 100kg for the Bessacarr. Am I right in assuming I can lighten this nose weight by adjusting things around a little ??. The other point is will it be less stable at maximum nose weight when towing with the Toyota .
I can still walk away from this deal at a cost of a couple of hundred pounds, should this nose weight thing be critical.
Val & Frank
Val & Frank
