Using two part epoxy paints
Dec 22, 2012
7
I am considering renewing the paint on the front panel of my caravan using two part epoxy paint. Has anyone experience of using this paint and any tips they could give me.
Apr 19, 2017
361
I have used them in the past on my boat, and quite frankly find I get better, and longer lasting, results using conventional paints.
Mixing proportions are very critical which can be difficult if not using a complete can. Application and curing conditions are also critical (both temperature and humidity).
5,474
Brian,
Make and model and material type of your front panel will help please.
Were you going to spray it yourself?
A good motorcycle body repair shop may be worth a punt
Dec 22, 2012
7
The van is a stealth Concordia (not many around). I have been declined by two local repair shops who find the job outside their capabilities, but I I am not afraid to try the job myself. The front panel is grp with a well worn gel coat which I have flatted out, but I am worried about the time factor before the primer starts to go off. Thanks for your input.
Brian.108
Dec 13, 2017
72
Anyone ever tried to use car wrap vinyl? Could have a fancy carbon look front end. When it gets damaged again, peel it off and go again. You can get it in pretty big sheets to do the sides of vans and lorries so should be able to get some big enough to do front panels of a caravan. Have any sort of design you fancy. Starsky and Hutch red and white??
Oct 12, 2013
3,037
Red & white ?!?! You may be taken for Sunderland supporters perish the thought :p
