vauxhall vectra 2.0 dti
Jun 17, 2005
have just bought a sterling europa 460 would like to know if my car is suitable for towing this model i am new to caravaning
930
Unfortunately, you don't say whether you have the current Vectra or the previous model or whether it is a saloon or an estate. Also, one would have to know the year of manufacture of your Sterling Europa 460 as it has grown from 1100kg in 1999 to 1250kg for 2005. I don't know the kerbweight of your Vectra (check on the VIN plate) but at worst, you could be around 95% and very close to the maximum permissible towload, too (the lowest figure is for the old Vectra estate at 1200kg) so the outfit could be marginal. But, one can only give you a definitive answer if you can supply more information.
Jun 17, 2005
car kerb weight is 1420kg europa 460 is 2berth 1998 model
930
According to the figure I have for an early Sterling Europa 460 (MTPLM of 1100kg), you'll be OK weight ratiowise (under 80%). Also based on that figure, you'll be quite legal as the lowest max. permissible towload of all Vectra 2.0DTI's, whether old or current model, is 1200kg.
May 23, 2005
21
These are the towing weights for the new shape Vectra 2.0 dti Expression.
Towing weight (kg)
1500
Kerb weight (kg) 1470
Hope this helps
930
The figure that I quoted, Neil, was the lowest of all 2.0DTI's, i.e. for the old model as an estate car. I'm not denying that it can be as high as 1500kg for other variants of the 2.0DTI but I was just stating the worst case.
930
Just another note. The figure that you quote for the current Vectra 2.0DTI, Neil, applies to the saloon only. For the estate it's 1400kg.
