Vauxhall Zafira/Lunar Venus 5 berth 92
I have had an offer on my Lunar venus 1992 van 5 berth,but I am not sure if the car the buyer has is ok.Vauxhall Zafira 2004 model 1.8 or 2ltr.
Can anyone URGENTLY pls help.
I know alot of people would sell their van to anyone but this is my SGT at work(police)!!!
I have a 1.8ltr which tows a fleetwood 2 berth (mtplm 1050) very easily the car weighs in at 1440k and so could comfortably tow 1225k (85%) having gear ratios for carrying 7 people helps
graham
if he has a 2ltr zafira it must be a GSI turbo that weighs in at 1560KG and would easily pull the van (depending it's weight). The 2.2 ltr is about 1450kg (from memory). I tow a '93 Coachman Genius 460/4 (approx 1150kg fully loaded) all up with a zafira GSI with absolutely no problems (don't even get any noticable suspension deflection)
I believe the Zafira has a kerbweight of 1300-1400Kg BUT its towing limit is much lower which restricts its towabillity.
The Vauxhall website will give exact figures
I have a vauxhall Zafira ans it has a kerb weight of 1350 however vauxhall say you can not pull more than 1100. I would tell them to double check with Vauxhall
495
lutzschelisch.wix.com
Stuart was referring to the 1.8 or 2 litre which have a permissible towload of 1300kg (1200kg for the automatic) and 1400kg respectively.
If the max. towlaod of your Zafira is 1100kg, Janet, then you must have a 1.6.
