Vectra 2.0 dti estate
Mar 27, 2005
163
anyone own one of these as a towcar , how do they rate & what sort of mpg do you get towing ?
My van weighs 1150 kg max.
cheers
Hi
my wife has the hatchback version. Just checked this weekend- went from Northampton to New Mills, High Peak. Mixture of motorway and 'A' roads and got 32mpg which I am hppay with. We stuck to speed limits but didn't go below them! On a trip, get about 52, so its ecomonical.
had a dti sri 130 hatchback 02 plate,mpg was brilliant,better than 2.0 dti which i had before that.dti sri combined round the doors and going to work A roads over 40 mpg,on a run 55,towing a swift baronnette 1025-1265kg,and avondale osprey 1250-1450 over 30 mpg.changed car only because of heavier osprey .would highly recommend to anyone(kerbweight i think is round the 1425-30kg area
Hi Jon,
I own a Vectra 2.2 DTI estate
Fuel consumption
Local solo av 46 mpg.
Towing a bailey pageant Imperial 1181 kg av 36 mpg.
We normally have the air con for the dog when we are towing,
The only grouse I havewith the Vectre is the sidewindows,you need special extended mirrors( vecta Only)to fit them, apart from that The vectra tows like a dream.
Roy.
Hi Jon,
Fuel consumption
Roy.
ment mirrows not windows.roy.
Hi Jon,
Fuel consumption
Roy.
millenco i found were the best mirrors
Hi Jon,
Fuel consumption
Roy.
Towing mirrors - I was told the Vauxhall ones are the only ones that fit as they are streamlined and are expensive - around
