Lutz said:
colin-yorkshire said:
hi Lutz, nowhere on the Meriva does the VIN plate or V5c give the maximum trailer weight, only the max axel weights and GVW and GTW deducting the GVW from the GTW would give a max tow weight of 1225kg + 50kg noseweight = 1275kg however it is not untill reading the handbook that the manufacturer states the maximum trailer weight is 1200kg for that model. similary some Rover models have the maximum tow weight pegged at 1000kg even though doing the maths gives a tow weight of 1375 kg.
I would suggest that this lower figure is the one to use, instead of relying on a calculator for a figure,
I don't know what Ford recommmend for their models but the fact remains would you tow a 1600kg van over the Alps with a Focus.
Manufacturers don't quote maximum trailer weights but maximum braked trailer or towed weights. The brakes on the trailer act on its axle only, not its total weight. It's the job of the car's brakes to act on the total weight of the car, including the noseweight which the car is carrying, not towing. Therefore, the noseweight part of the trailer's total weight is NOT included in 'braked trailer weight'.
Well now even I'm confused
and I thought I was well savvy and up on all the weight issues,
I just don't see how just doing the maths would square the circle. we all know the issue is complex but things just don't add up.
take the Meriva for instance there are no weights on the VC5 as it is a 2004 model, so the only reference point is the VIN plate, this reads, 1.1935kg, 2. 3160kg. 3. 1045kg. 4. 950kg.now given that
3.is front axel load and
4.is rear axel load
adding the two together should give the gross vehicle weight in 1. ie 1935kg but it does not because 3. and 4. added together is 1995kg so there is a difference of 60kg, now the maximum noseweight of the Meriva is 50kg, this cannot be added to the rear axel weight although this is where it goes, because you would exeed the maximum of 1.1935kg the gross vehicle weight if you deduct it from 4. this lowers the max rear axel weight from 950kg to 900kg assuming the car was fully loaded,
if weighed by VOSA and the front axel weight was 1040kg and in limits and the rear axel inc noseweight was 945kg again within limits you would still be overweight by 50 kg ie 1040+945= 1985kg.as the GVW is plated at 1935kg.
this leads to the conclusion that the assumtion as stated above that the figure for 3. and 4. added together makes 1. is WRONG.
if the front axel is fully loaded the rear axel cannot be and has to be reduced or visa versa adding the noseweight to the rear axel must reduce the gross vehicle weight by a factor of x2 ie 50kg of noseweight + 50kg difference between axels =100kg.
before hitching up the van the gross vehicle weight or GVW cannot be any more than 100kg underweight or you would be overweight by the time the van was on the back.
secondly the previously stated assumtion that 1. GVW deducted from 2. GTW gives a accurate maximum trailer weight it DOES NOT. and also must be wrong, because some vehicle manufacturers give a max trailer weight well below the plated equivelent. again in the Meriva the GTW or 2. is 3160kg while the GVW in 1. is 1935kg, 2 minus 1 = 1225kg given that this is the trailed weight (minus noseweight) as stated by Lutz, would mean a van with a MTPLM of 1275kg could be towed ie 1225kg +50kg noseweight.
but the handbook clearly states the "max braked tailer weight" is 1200kg for my model even if you add the nose weight (allthough there is no mention of it) the plated weight would be 25kg over,
but thats not the whole picture because using the plate to make calculations adding 3.and 4. and and the calculated tow maximum 1275kg deduductiing from 2. giives a GTW of 3220kg or 60kg over the plated GVW stated in 2.
but deducting the max trailer weight of 1200kg from the plated GTW, in 2. gives a figure of 1960kg or 25kg over the plated GVW in 1.
which ever way the weights are calculated via the VIN plate the figures just don't add up
