ProfJohnL said:
Hello TR
From your description I gather you have a twin axle caravan. TA's can actually present a real problem to weigh properly unless provision is made to cover these eventualities.
"You should remember for I have often told you so, Oh best beloved" (Kipling) that nose load must be be measured at the actual towing height. This is because the position of the caravan centre of mass will move fore and aft if the caravan is tipped up or down. The horizontal change in its position relative to the caravans axles changes the turning moment that produces the nose load. This change in load vs hitch height is far more dramatic and complicated for TA's compared to SA's. that is why NONE of the available noseweight gauges are really fit for purpose - even the Milenco because it does not offer height adjustment and when it is loaded it changes its length!!!
The reasons for nose load changes on TA's can also compromise weighbridge analysis of axle loads on TA's
Because the suspension units used on most TA caravans is fully independent, when one axle has to rise to ride over something none of the increased load change is shared with the second axle. If the leading axle has to rise to get onto the weighbridge it has to compress the suspension unit to do so, That means the suspension unit is pushing down harder because it is compressed. By doing so it unloads the trailing axle, and the weight is transferred to the leading axle. If the weighbridge has a step of only 5mm this could easily see an extra 30 to 40kg added to the axle load. The same thing will happen to the trailing axle when it reaches the weigh bridge beam, so another 40kg could be added thus giving the appearance the caravan is 80kg heavier than it really is.
The converse is also true, if the weighbridge beam is lower than the surrounding ground as the wheel s drop onto it, the bean will under read the caravans weight.
I am also concerned at the way you describe calculating your nose load figure. Because the hitch on the car is behind the rear axle, any load applied to the hitch will indeed compress the rear suspension, but at the same time it will unload the front axle by a smaller amount. You need to take both of these changes in axle loads into account to establish the applied nose load.
There is nothing wrong in keeping a spreadsheet of loaded items, but the methodology is far from perfect for establishing the total load. The problem lies with inaccuracies of measuring small masses, each of which will have an error. By adding all the small readings together you can get a compounding error which can have a large standard deviation. Its not uncommon to find tabulated results are quite different to the actual weight of the caravan.
These types of errors are particularly important for caravan owners, as we so often work very close to several upper load limits. By not measuring our loads correctly, it is so easy for a caravan to slip over one of the legal limits, with possible consequences that can bring.
Hi PJL. I can see why you have the "handle" Prof !!!!!!!!!!!!!!!!! You are actually telling me everything that I have ever advocated and in the eyes of many BANGED ON ABOUT for a very very long time - indeed long before I ever subscribed to this and or any other caravan related forum.
As far as towing height is concerned I have even gone into great detail as to how I achieved this critical factor/consideration prior to hooking the twin-axle caravan on the back of the car. Always carried out on level and flat ground.
I fully understand your point/points about the complexity of towing twin-axle caravans and or 8x4 and larger twin axle boxed trailers. The Dynamics of Towing are considerably more complex and constantly variable with twin axle than with single axle caravan/trailers.
When ever I took out the caravan and indeed upon the return journey the routines were the same initially the caravan would be loaded and adjustments made on the basis of using my Milenco Nose-weight Gauge and setting the hitch-head at the towball centre height relevant to that of the car after ensuring that it was at the optimum height when the 75kgs maximum hitch-head load was applied to the ball - this 75kgs was coincidentally the same for both the car and the hitch-head.
I found that with the twin axle caravans that I had owned over the years - finding the fulcrum point with an empty caravan on the gauge and chocked front and rear of the axles was relatively easy. Then the loaded and all in stout cardboard boxes was easily position and secured from movement.
I do not use Plate Bridges because of the known issues/potential discrepancies,a number of operators will not allow the removal of the caravan/trailer whilst the total load is on the plate.- the Dynamic Axle Weighbridge is actually a fine beam set into a concrete bed and all on perfectly level/flat ground. They give variable and recorded readings as one passes across at a slow roll pace.. The individual axle weights are all perfectly visible on a large digital read-out at the head of the weigh area.
When loads/loading is being carried out the smaller items are weighed as box loads and not individual items because of the potential for compounding errors. Larger items are weighed and rounded-up NOT down.
At the end of the day all is carried out on flat and level ground and in that respect the optimum is then as neutral a result as can be reasonably expected - from there-on in the towing dynamics are not already influenced by inaccuracies created by gradient and or uneven ground.
Yes - the tow-ball is behind the axle but that is the case with every vehicle fitted with a tow- and on can only hope and trust that the vehicle manufacturers that homologate their vehicles and deem them fit for towing are fully in the knowledge of that very detail - as are the various manufacturers of towing equipment.
That is essentially why the home-made/DIY/Bodged tow-bars are outlawed and all now have to be approved and accepted/approved by the vehicle manufacturers as fit for purpose.
In conclusion - In my 50yrs of towing al-sorts with al-sorts I have only ever had one serious snake which was caused by a holiday coach from National Express Coaches travelling far to fast and damned near taking my towing mirrors off of the car and a tow-bar frame on a previous employers vehicle suffering a very serious weld failure whilst on-route to Yorkshire via Scout Head in the late 60's with a very large trailer loaded with contract furniture.
