very excited new caravanner
Jun 3, 2007
12
Just a quick hello to introduce ourselves. We have just purchased a Avondale Mayfair 556/6 it is our first caravan and we have just returned from our first weekend away. My family and I absolutely love it, compared to our camping holidays its absolute luxury. The funny thing is we havent got a clue what we are doing which makes it exciting but sometimes very frustrating. The whole towing experience was daunting but looking forward to next trip. Any advice with regards towing and how it should feel gratefully appreciated.
Jadiex
May 31, 2007
51
Hi Jadie & family,
Firstly welcome to caravaning, it will all fall into place and the fun is just starting. You have done the hardest thing thats going away for on your first trip, it just gets better from now on.
You need to set out different things for the family to do when you get on site, if you have children let then go and fill up the water together and fetch it back together if they are old enough and big enough to pull it. It is new to you all and there are so many different things to do, once you have helped out with something the next time will be easier for you all, you can then quickly get set up and do the best thing of all relax. If you have an awning make it something you all can help with, my kids love to help when our awning is up pegging it out, I set it up and secure each corner then we do it from there together.
It can be frustrating at first but you are new to it this will pass. Towing will have been the hardest part for you all as you will have been watching it through the rear window and through the mirrors, this will pass as long as you have checked and double checked the hitch and stabaliser and electrics and safety cable you should be fine. All you have to do is remember the van is wider than the car and you have probably doubled the length of your car which will need a greater distance to stop.
The most important thing Jadie in all of this enjoy the years of caravaning ahead of you all, you cant beat it.
Jun 3, 2007
12
Hi Ian
Thanks for your welcome and good advice. We are setting off on our next trip next week and this time a will definately make a list . We have an awning but haven't yet tried it out, what would you recommend for the groundsheet? Also is it normal for the noseweight to weigh 100kg when practically empty and am i right in thinking it goes down the more stuff you have packed?
Thanks for your help
Jadie
Jun 3, 2007
12
Hi Jadie & family,
Hi Ian
Thanks for you welcome and advice, i've asked you some more questions but posted it to reply topic. We would appreciate your help.
Jadie
Jan 2, 2006
2,431
Jadie,welcome to the madhouse.
There is another post under this section referring to noseweight which may help failing that a search of the forum will find many threads on this subject.As Ian P has said you have done the hard bit by doing the first journey if you have a good car/van match you should have no problems so long as you allow extra time to stop and take a slightly wider swing on left turns.Practice reversing every chance you get even when not necessary as sooner or later you will have to do it wothout a choice.
Good advice getting all involved in setting up,with regard to the awning when you arrive,dont put it up straight away have a cuppa and chill for a bit then do it ,as it can be a trial until you are used to it and even then a bit of a chore.
Groundsheet personal choice,and depends on use if on good pitch and no inner tent then breathable is good for you and the grass but not so if using inner tent as water will get through in bad weather.
A tip from me is make sure you have a spare wheel and a proper caravan jack and know how to change it.
Use equipment from the house to start with and over time kit the van out with all its own kit that way all you will need is to load the wardrobe and hit the road.
What ever you do remember one thing,enjoy yourself!
Jan 2, 2006
2,431
Jan 2, 2006
2,431
Looks like I have developed a stammer! :eek:)
May 31, 2007
51
You have either got a stammer plotter or we have entered a tunnel and it's your echo.o.o.o.o.o.o.o
Spot on about the spare wheel check the wheel size and number of wheel nuts as some have 4 and some like the Bailey have 5 and as plotter said dont forget a jack suitable for getting under the chassis of the caravan, do not be tempted to use the corner steadys to lift the caravan incase of a flat, I use a small trolly jack as it fits under the van with ease.
Jan 19, 2007
247
Hi Jadie
Have you considered doing a towing course...both the big clubs run them. The day and a half one my husband and I did the weekend before we collected our first caravan covered much more than towing/reversing. It was good for what/how to check things, eg noseweight, loading. It covered setting up and making lists so you don't forget to do things and find you've missed something important, the advantages/disadvantages of different types of pitch and much more. For us, it probably lead to a much smoother, but nevertheless very exciting introduction to caravanning.
Happy caravanning
Denise
Feb 15, 2006
2,919
i have the same van but mine is the godiva special. the nose weight on this model of van is high. when we picked ours up new in oct 05 we had a 307sw and the max towball weight of that car is 60 so the car was bottoming out. we sent the 307sw back and bought a 4 x 4. we did panic it was our 1st van.
we now have a new kia sedona and will be changing the van in sept this year.
what we did to get the nose weight of the van down is to take everything out of the front locker. dont put much in the draws and just put sleeping bags under the front seats. we have to put the awning, windbreaks, tv etc on the bunks and things like dvd, play station under theside dinette over the axel. loading the van this way we managed to get the nose weight 80 - 85.
that model of avondale the wheels are slightly off centre towards the back making it nose heavy.
if you dont mind me asking what car do you tow it with?.
jo-anne
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
dghdto
