Aug 17, 2025
19
6
Hi picked up caravan first one ever, it is eddis odyssey 550 single axel, van in good condition for year 2008. On the drive home was fine, but when I got on to duel carriageway any thing above 45/50 mph I get vibration when I have my foot on the accelerator but when I don't it is smooth no vibration I tow with a 2012 nissan x trail the car looks solid. I would like to know so suggestions of wot the issue could be, caravan has been sited for the last 2 years.
Thanks for any help
Stephan
8,952
Are you sure it is the caravan causing the vibration. Where does it feel to be coming from. I had a Skoda Superb DSG diesel that was fine solo, but started to develop a vibration when the van was hooked up. It occurred at motorway speeds 50-60mph when accelerating. Specialist diagnostics and test drives could not find the source of the problem; then it started to be noticeable when solo.
Reactions: Stephan Marchant
Aug 17, 2025
19
6
How old are the tyres? If more than 5 years, change them even if they look good. With caravan not moving for 2 years it may have affected the tyres. When last was the caravan serviced ?
The paper work says had a full check safety and damp 15/1/25 the tyres do look old. But I don't understand why vibration only above 50mph but ok when coasting
Aug 17, 2025
19
6
The car has been well looked after full service history it has had some new suspension parts on the front I have towed a small box trailer and had no issues with that but was light 500kg van is 1500kg
4,283
Towing add a lot of extra load to the tow vehicle, and it can expose characteristics that you may not notice when driving solo. This is one of the reasons why it is so important to ensure your tow vehicle and trailer are maintained in good condition.
As the problem seems to be speed related immediately suggests to me it could be insufficient nose load. The static nose load you set by adjusting the location of any load in in the caravan should counter and exceed the towing aerodynamics of the caravan which generally produce a lifting torque on the hitch which is very much speed dependant.
It might be worth getting the cars tow bar checked for loose fixings.
Remember that many cars should have increased tyre pressures when towing, check your owners manual for details. Tyres are of course very important, but often if stood for long periods heavily loaded (and caravans usually are) they tyres can stiffen and develop a flat spot which especially with older tyres may become a permanent problem. But that would be noticeable at all speeds.
You tell us the caravan has been sited for the last two years, in which case it's unlikely to have had a "full service" on its running gear. mindful of the fact the caravan is now 17 years old, it's far more likely to have deeper issues. That's one of the reasons why I and others strongly recommend having an independent pre purchase inspection carried out by an Approved Workshop Scheme engineer to establish the condition of the caravan.
I strongly advise you have the caravans running gear checked, and also look at the advice about where to load items into the caravan to improve towing handling.
8,952
My car too was well looked after bu
My car was well looked after too, but that didn’t stop it starting to exhibit a vibration when towing at certain speed/power. Various views were offered in support of diagnostic checks but when it started to show signs during solo driving that’s when I got more concerned
Aug 17, 2025
19
6
The towing ball is from nissan the ball weight says 100kg to my understanding the van i am towing should be 70 to 90 kg so in the right scope. They did put a full size awning in the rear of the van could this be the issue or make the issue worse.do you know of anyway to check the nose weight if the van so I can make sure that the ball is up to the job.
4,487
Did you get a result about the vibration in the end. ?
4,487
Welcome to the forum Stephan, does your caravan have the AlKo, friction Damper on the tow hitch, or is it so you have a Non friction tow hitch where the tow ball is greased.
Apr 23, 2024
433
352
935
Given you have cracking on the tyres , do not tow it , a blowout will seriously damage the caravan also if on the motorway the rim could also be terminally damaged before you can get to a stop . I would also look at the service sheet done in January to see if any mention was made of the tyre condition.
Aug 17, 2025
19
6
In truth I have no idea as this is the first van I have had it does not look like a standard hitch but that all I know
566
340
19,135
This points to the motor fault and not the caravan. As said foot off accelerator and no vibration, but foot on vibrates. I would first be checking for driveshaft joints which is showing up with the extra load.
Reactions: JTQ
8,952
Yes I bought a Forester XT. Fortunately when the dealer took it for a run it didn’t show any sign if vibration.
From a well respected VAG independent in Melksham they thought it could be dual mass flywheel, injection issues, DSG bearng or clutches, but probably not Haldex as that had only recently been replaced. Advice was to run it on for longer to see what might further develop. 🤔
  • Wow
3,458
You can't work on "should be" - you need to measure the noseweight - bathroom scales under the jockey wheel will get an approximate reading - only approximate as the jockey isn't as far forward as the hitch.
Aug 17, 2025
19
6
I have checked the drive shafts and all seam to be ok no obvious damage all seam tight no movement but no real way of checking when underlay
Feb 18, 2019
28
14
10,535
Just a thought for you Stephan, we were on a motorway cruising at 55mph and my wife happened to look behind and noticed the front window catches were undone.
To cut to the chase, it was vibration from unbalanced wheels. If you are going to replace the tyres do get them balanced, it might solve the problem.
