Cleaned my 1 year old van after the winter and service last weekend and I thought (after reading on this forum about problems with
the freezing of the pump) I would fill the toilet tank and do test to see if all ok - yes the pump worked fine so I opened the cassette
door to check to see if everything OK in there and to my dismay found a steady leak of water through the blue pump housing so
I assume its going to be a cracked pump casing this was obviously missed at the service as it was only done end of Jan and
we have had no major frosty nights since then. Dealer is going to have it in to replace pump under guarantee he says this is a
common problem and he has replaced about 15 already - but is this going to be a problem whereby the pump gets changed annually - I made sure it was drained fully before winter my son has suggested putting some Vegetable oil in the tank over winter to stop the pump freezing up - does anyone on here have any other suggestions to combat this common problem. I know this has been covered before on this forum but is there a solution ?
