- Dec 27, 2022
- 734
- 508
- 5,135
You will need lots of microfibre cloths I have about 20๐ฒYou are in good company with both Gumpy and Beachball, so I might buy a pack and give it a try on the cars.
......used Patio Magic for years around the garden on fencing and hard surfaces.Best way to deal with Green Algae is spraying using one of These on a dry day with Patio Magic, go home come back a week later and it will be clean.
I've used it on boat covers and ports car soft tops as well as the caravan with no ill effects. You do have to make sure that it doesn't get into watercourses as it's harmful to water life.......used Patio Magic for years around the garden on fencing and hard surfaces.
No way am I spraying it over my caravan.
Each to their own!
Brilliant, thank you.You put the hose in the water container (a standard bucket runs out quickly so take something bigger) and attach the plastic soap container to the gun.
I suspect the basic cleaner is the same thingI see Greased Lightning do a specific Caravan and Motorhome version. Wonder what the difference is with a showroom version.
Well the Caravan & Motorhome Care Pack is a bit out of my budget at presentI suspect the basic cleaner is the same thing
It's just more and extra types of stuff.
Caravan & Motorhome Care Pack: This 6-piece kit includes Waterless Wash & Wax, Glass & Acrylic Cleaner, Bug & Bird Dropping Cleaner, Interior Cleaner, Fabric Stain Remover, and 10 microfibre cloths.
I hadn't looked at the price merely the contents, just as well I was sitting down๐ฑWell the Caravan & Motorhome Care Pack is a bit out of my budget at present
Never used it but according to their own instructions may cause problems with seals etc๐. Not for me!I've used it on boat covers and ports car soft tops as well as the caravan with no ill effects. You do have to make sure that it doesn't get into watercourses as it's harmful to water life.
Why wouldn't you use it on a caravan, it's only a fungicide and the caravan is a hard surface after all.
Price๐คชI see Greased Lightning do a specific Caravan and Motorhome version. Wonder what the difference is with a showroom version.
I read that Greased Lightning is used by bowling clubs to polish the bowls as itโs very easy to apply and buff, and with its grit level at 1500 it is even lower than Autoglym Super Resin Polish at 500 grit level. So minimal abrasive effect on the members bowls.Price๐คช
Or even other parts of the members bodies. ๐I'm glad the predictive text didn't change bowls to bowels. ๐
