waste pipe
Does anyone know where I can purchase the solid type waste outlet that joins the outlets together ? .It looks a lot easier than messing about with two pipes into my waste master
May 21, 2008
2,463
Hi Andy.
Towsure stock them as does any caravan accessory shop. I have got a setup of two Y piece adaptors on my van the first in the line joins both outlets to one pipe which is what your looking for and the second one reverses the pipe process so that I can use two waste masters. Saves time constantly trundleing a waste master especially when your a full timer like me.
Atb Steve L.
Aug 31, 2008
516
Hi Andy
Do you mean one of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItemVersion&item=200456151270&view=all&tid=470773619010
I am pleased with my purchase from this seller. I ordered it last Saturday and it arrived the following Tuesday. It fits fine and I am planning on getting a length of plastic waste pipe so that I can extend to use on serviced pitches in UK and on the Continent.
On the other hand I think it would be easy to make up the whole thing yourself. I'll post the size of the pipe after I'm next in the 'van.
Tim
Its 42 mm and you can get the parts from any DIY outlet such as B & Q
I have a long outlet to allow for sloping pitches and it can be fitted either to the left or the right
It just push fits the modern outlets
OOPS 32MM--oh for an edit!!
Mar 14, 2010
86
I purchased a length of 42mm pipe from B&Q but it is nearly impossible to fit it into the outlets as fitted standard on my 'van - any siggestions??
Hovis
You can purchase a black plastic adaptor where you plug in the two short lenghts of flexable waste pipes and connect a single small length of flex pipe to the outlet, a lot neater than the picture.
Hovis
It should be 32mm and then it will push fit into the outlets fitted to new vans
Sorry about the error which I had quickly corrected
You could use short lengths of caravan waste but it shouldn't be needed
Mar 14, 2010
86
Hovis
Thanks for that, However the 32mm is still a b***ar to push into the 'vans existing outlet!!
Hovis
Reg
Jan 12, 2008
435
Has anyone connected the two pipes together under the caravan before the outlet?
On my Bailey the pipes run together and one of the pipes obstructs the holes for the jacking point on the chassis.
So how can I connect the two pipes together when they are running parallel?
This would mean that I will only have one outlet pipe which would be a bonus.
