Waste water pipes
Aug 30, 2006
I have just purchased a Lunar Quasar FB with 3 waste outlets.The problem is you cant fit 3 waste pipes into the waste tank.I have bought a 2 into 1 adaptor which makes it slightly easier but can anyone suggest a ready made plumbing kit that will make three pipes go into one?
Mar 18, 2006
47
hi alex.. my caravan too as 3 waste outlets but seeing as we don't use the shower in our van i don't conect up the shower outlet.. i have a made my own connection out of plumbing parts from b & q or somewhere..and that alows the 2 pipes to fit into the wastemaster.. if you dont intend to use the shower, dont worry about the waste pipe daz
Aug 30, 2006
Darren
Thanks for the advice but in the magazine this month there is just what I was looking for. Go to www.care-avan.co.uk and they do a triple waste away for
Alex you can see from the link you gave what is used.
A 32mm swept T from screwfix is 65p
You would need 2 of them and a 32mm elbow @55p plus a length of 32mm pipe (99p in Focus)
So even allowing for B & Q prices being more than screwfix you coul make one up for a lot less and have a length of 32mm pipe left to fill the aquaroll etc
The caravan flexible pipe just fits a push fit connector so its easy to make the connection to the van as well
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101167&ts=10257&id=12701
