Raging idiot? Daft ape? Brainless twit? Yes these are words I would use to describe myself. Why, I hear you all ask (except those that know me)? Well it all started one windy rainy evening, while trying to set up the caravan on an unfamiliar site. I try and get everything in the correct order, from reversing to winding down the steadies to making the first cuppa, but this night, due (I would like to think) to the wild weather outside I got it wrong! Hook up connected, fill front inboard tank, connect up water to aqua role, switch on space heater and water heater, better turn on the gas too, little time to get that water hot.... Anyone spot the mistake? No, nor did I until I turned on the hot water tap and heard the water pump gurgle into life and fill up the water heater! So not only had I turned on the mains heater without water inside, I had switched on the gas too, hey and guess what, no hot water. After rubbing the tears away before blindness set in, I turned it all off and read the instructions. Apparently, if I switch off the mains and trip switch it resets the heater and everything should be fine, only it didn't. Still works on gas but won't work on electricity. Have I missed something or have I got a bill coming to me? The caravan is only 6 months old; tell me I haven't broken it already.
