- Oct 9, 2013
- 27
- 0
- 18,530
We have just bought a second hand Fiat Ducato Auto-Roller motorhome, 1997/98 reg. We paid a very good price for it, but we knew there was water damage on the ceiling, I checked the floors and walls are they appear to be ok, (not spongy) I have just started removing the roof light to inspect and see how bad it exactly is. And its pretty bad, it looks like its been leaking around the roof light for quite some time.
I am looking for some advice on how best to tackle this, I have removed the lights. and the roof light. I thought I would take down all the ceiling as far as the cab as it appears dry there. cut a straight edge where I can join the new ceiling and old. I'm guessing all the insulation will have had it and need replacing. Then replacing the ceiling panels, I've been looking where you can buy these from for the proper motorhome ones. I am also thinking of upgrading the lighting to LED downlighters while I have the ceiling down.
Which is the best insulation to use? and sealant to use? I have been researching the different ones Silkaflex 220 & 512 also Everbuild Stixall extreme power - this is their description of the product "Hybrid PMS polymer technology. Combined building adhesive and sealant, bonds and seals virtually everything to anything. Water resistant, can be applied to wet surfaces"
Also Everbuild Puraflex 40 "Premium quality one-part high modulus polyurethane sealant and adhesive that provides exceptional resistance to mechanical wear. Used in the engineering, caravan and marine industries and for sealing floor joints in ceramic installations that are subject to high traffic. Excellent chemical resistance"
These are half the price of Silkaflex 512, I've heard some people using Silka Silkaflex EBT from screwfix.
The reason I am taking down the inside first before going up and sealing the outside is because I'm not sure of how they construct motorhome ceiling for structural support if its timber then they could all be rotted, if its aluminium or steel they could be corroded.
I would appreciate any help and guidance on this matter.
Many thanks
Paul
Many thanks
Paul
