I have a 2009 Coachman VIP 545/4, and, at the end of last year drained off the water system, and left the hot and cold drain taps in the open position. To be rady to start the season, I have been purifying the aquaroll, and then I usually pump this through the system, allow to stand overnight, then pump through clean water and away we go. I connected the pump, closed the drain taps, ensured the kitchen tap was open and switched on the pump (caravan connected to mains electric). Pump whirred, tap coughed, then nothing. Pump ran for several minutes ( enough to fill heater tank), but nothing through taps. Opened each drain tap in turn, and water runs out. Checked in aquaroll, and hardly any water has been used.
As water comes out of drain taps, I assume that pump is working ok, so am at a loss as to why water is not getting through to taps.
Anyone got any suggestions? All gratefully accepted and tried!!
