Water pipe connectors/fittings
May 27, 2006
298
My water system needs one or 2 elbow etc fitted to help avoid kinks in the piping and a in line drain down tap and outlet.
Its piped with 10mm food grade piping.
Any ideas please?
I fitted a 12mm push fit shut-off Valve as a drain down tap. Have a look at www.w4limited.com who might do the fittings you require.
Message part two . . . said item does not seem to appear on the web site. However the label it came with bears the part number 31270 and a bar code 5 01932831207.
