Has anyone got ideas to solve problem of water pump not switching off.
I have a truma water system (no pressure switch) and after the winter, have filled the system for the first time but the pump did not stop running and the pressure build caused the taps blow the water pipes off, the pump only stopped when the electric for the pump was switched off.
I have since dissconected the bathroom tap and can hear the micro switch on the kitchen tap click on and off when tried but the water tank does not seem to fill it is as if the water is going straight to the tap, all this and the pump does not switch of, only when electric to the pump is turned off. HELP
