The gasket on our internal water pump, for the taps etc, gave up & we couldn't get any replacements (Buccanneer caravan about 10 years old) so we had no chioce but to get a new pump. A whale 12 ltr unit was installed, but when it's switched on & all taps are off it pulses on every few seconds & the excess water is forced out of our Carver water heater (outside thankfully).
Now this is our first caravan so I've no experience of these matters, but upon some investigation I found that the new pump's cutout is at 45psi whereas the Carver's safety valve operates at 44psi. The old pump has 16psi written on it so I presume that's its cutout & the Carver's manual states that it expects water at about 20psi so that seems correct.
So my questions are:
- Does my theory sound right, is the new pressure just too high for the rest of the water system? (If not what do you think it is)
- Can I do anything about it without changing the pump?
- Where can I source a pump with the correct psi (as the people who sold me this one say its the 'normal' one & don't stock a lower psi model).
Any help gratefully appreciated.
