Water pump, 12V terminal pins
I have a trauma crystal Mk2 pump with brass 12V terminals that are corroded.
I have purchased new terminals but how do i change them.
They seem to have an undercut halfway along which seems to be moulded in, meaning i would have to knock them out. This may destroy the plastic plug.
I have asked some suppliers but they do not seem to know the answer.
Can you help.
If you have the Crystal 2 (with the filter) or Crystal Compact (without the filter), inside the van disconnect the wires to the pins, note which is which!
Remove the grub screw completely then tap the pins outwards.
Fit new pins from front of unit having removed the grub screws first!
