Water pump lunar chiron
3,166
Hi..
Does anyone own a lunar chiron ? I am struggling to find where the water pump is and it's driving me insane
I'd expect it to be a removeable submersible pump that plugs into the socket on the outside of the caravan - it could be stored anywhere!
4,889
Check the connections where it plugs in first as they tend to get corroded and make a poor connection. Use some sandpaper to clean the connections.
Jan 19, 2002
1,686
530
Worth also checking that the impeller can rotate. Usually there is a filter cap clipped on the end, remove then reach in with a tiny screwdriver and try to turn it in either direction then try again. We assume you have the ‘pump’ switch activated an the control panel and that other 12 volt lights etc work.
1,818
Looking at the photos on Google it looks to have a Truma drop in pump, later Lunars also use this system. These are widely available from caravan accessory shops.
