Sorry cris but you have lost me on this one! The Senator 5 pump is an external pump, fitted to the floor of the van. Can't figure out your suggestion to fit it inside a tupperware container. ๐Noisy pump quietened by placing the pump in a thick walled tupperware style cup or or container.
Drill a hole in the lid that the outlet hose fits tightly through and perforate the cup with small holes so the water flows to the pump that must not touch the sides. Some pieces of hose can be used as soft flexilble spacers.
We found most inboard pump noise seems to come from it vibrating against the tank. Trial and error to find the best pipe position and set inside another container works for us and for friends and family with kids who sleep over the pump.
cris,Rob-T. Assumed it was still an internal pump.
As it's an external surely it could be put in something or surrounded by something that will quieten the noise.
If it runs quiet detached from its mounting point (assuming it has one) the noise is being amplified by the vans structure or through pipes vibrating. If it is still noisy when held away from the mounting point what else can you do apart from muffle it. Again a cheap plastic container that could be easily cut to accomodate pipes and lined with foam to muffle the sound springs to mind ๐
Hi Keith,Hi Rob,
The same pump is fitted in our Senator Oklahoma. When you write 'pulsing', do mean the pump is cutting in and out rapidly? If so, the handbook's fault-finding chart states:-
"Pump cycles on & off excessively when tap(s) are open" Cause = "Excessive back pressure". Solution = "Check pipework for kinks and that filters etc are clear. Check shower rose/taps for blockages."
Obviously on a brand new van none of the above should apply! When you set the two selector levers on the pump to fill the inboard tank, does it pulsate then or only when feeding direct to the taps? Note that the pump will run-on briefly after most use as the system pressure necessary to cut the pump out is built-up. (The pump is operated by a pressure-switch).
Hopefully you can find a solution without having to make the trip back to the dealer.
