I have just fitted a new water pump in my caravan, and it still will not pump water to the taps. Being very new to caravaning is there any thing else i should be looking at to rectify this problem.
Many Thanks
Janet
Many Thanks
Janet
Hi HamerJanet,
What type of water pump do you have in your caravan?
If it is a pump which goes into your water carrier, switch your pump on at the control panel, open a tap and go outside to see if the pump is running.
If it is not runnung open all your taps to see if this will make it run.If you have microswitches in your taps then one may have failed.If one tap works and one doesn't then a microswitch has most probably failed.
If no water comes out of any taps do you have a pressure switch under the bunk? This may need resetting.
It is also possible that if your pump was faulty it may have blown a fuse so check the fuse.
It is also worth checking the electrical connections which the pump plugs into to see if they are live with the pump switched on and the taps open. You could have a loose wire.
Hamer
