Water Pump
I have a whale water pump and everytime I turn on a tap in the caravan it leaks water down the side of our van by the connector.
Is this because the pump has gone?
Stuart,
I believe there are two rubber O rings on the connection to the caravan. Have you tried checking or replacing them?
Robert
Hi Stuart
If you remove the 2 screws from pump conector and check to see if pipes are loose, as most people remove pump by pulling on pipes instead of pump body. Had to replace my pump because i was unable to reseal unit. Mark
Hi it was me ordered new pump and hope it solves the problem,nice site Warwick booked again.Do you want to sell your blue shocks if so as the moderator to pass on my email address mark
Missed you on Monday
I was going to give you my email address so if the Mod will pass it on its Ok
Have had my moneys worth out of the shocks so you are welcome to them
Will arrange postage or meet in Nantwich etc
Thanks i have asked Parksy (moderator) to forward my email address to you regards mark
