Water pump
Oct 9, 2023
When my crystal2 water pump is connected and water is turned on it leaks out with pressure at the connection and the pump keeps running can any one help
Nov 30, 2022
934
791
1,135
Clearly there is something wrong with the connection that leaks, so you need to find out why it is leaking at that point.
1,904
6,935
It is often the rubber ‘O’ rings that have failed. Easy to change, make sure everything is clean then put a touch of silicone grease on.
285
155
4,735
I did it too on my Elddis - there's a thread on this forum where I describe how I did it, the mistakes I made and the lessons I learned:
