Sterilising the blue hose will not remove the muck which coats the inside of it. I use a piece of stiff wire (a straightened coat hanger) bent flat over a slither of clean rag. It works well. I discovered how mucky they get when I changed a broken pistol connector and took the opportunity to rod it through.
If you don’t drink the van water a food grade hose isn’t required. But if you use one for drinking supply you’ve just opened a bag of worms ( or algae) akin to measuring noseweight. 🤭When you sterilise the water system on the van you take it for granted it’s clean, with the blue hose mentioned by kerbdog I assume you mean the hose for a serviced pitch, I had the same dilemma, it looks awful but it’s about 20ft long so trying to get something through to use as a pull through was impossible and believe me I tried, I could see loads of algae so I ditched the hose and bought a replacement length, as for the rest of the system it’s a case of what the eyes don’t see etc etc, this year I bought the Aldi service pitch kit for £15, the float that comes with it is pretty crap but the hose is perfectly ok, not sure how much it would be to just buy a new length of food grade hose from a dealer, I also wonder if food grade hose is strictly needed if you only use it for a few weeks, would it deteriorate in that short time?
BP
If my garden hose is anything to go by it sits outside all year and lasts and lasts.Morning OC, I haven’t ever used anything other than food grade hose when on a serviced pitch, I just wondered if it was hose that wasn’t food grade how soon would it degrade, I actually bought 3 of the Aldi water kits just so I’ve got 3 replacement food grade hoses ready and waiting, at the end of this season I can bin the hose and use a new one next spring, I book serviced pitches whenever I can as you may guess lol
So do we.And I do drink the water from the van system.
We have the Whale roll flat hose and been using it regularly for about 3 years and no issues. I seem to recall yours ended up with numerous pin holes?We rarely go on service pitches. But we ended up somehow, with two food grade hoses. One of which was roll flat. When I had the opportunity at a CL in Folkestone, I got it out. It had completely disintigrated!
He other one, (not roll flat) still seems fine years later. But rarely used.
I just replaced my retractable 40mtr hose in the garden ,out of curiosity i spliced open the middle section for a nosey, 10 yrs old and i couldnt belive it was spotless .If my garden hose is anything to go by it sits outside all year and lasts and lasts.
P.s we also drink van water 👍
Not all algae is dangerous, but the problem is we don't have the means to check the difference between the ok and the dangerous.so its simplest to assume a clean pipe is needed.
There also seems to be some confusion about what a "food grade" pipe is. Most modern day hose are manufactured from plastics, but there are many different types of plastic, and some use materials that are know to be harmful because some of their chemical make up or manufacturing process materials can leech out and be carried away by the water passing through them.
It may be different now but just a few years ago, the yellow colour in some fittings and hoses was created using cadmium. This is a highly toxic.
Also to allow for the flexibility in a hose a plasticiser is usually added. Some of these can be toxic, and becasue they act a bit like a lubricant they also can leach out, which is one of the reasons why older plastic pipes loose their flexibility.
There is conception that plastic pipes have an impervious surface, In flexible pipes that certainly isn't true, which is why some chemicals can leech out but it also explains how algae can attach to the inner surface and are not washed away. - and why a pipe often doesn't look as clean even though yo may have scrubbed the surface.
The dangers of issues noted above are normally relatively small, but where water is standing in the pipework there is a significantly raised risk of high levels of contaminants leaching and building up in the water contained in the system
Food grade pipes have to be shown to be free from toxic formulations, and that is why they must be used in systems where water might be drunk.
Our 1986 house has just such a cold water tank in the loft. It feeds upstairs H and C and downstairs too. But the kitchen sink tap has a direct mains connection.It is my believe, based only on observation, that water held in an enclosed system. ie. mains water. Stays comparatively safe. But in systems open to the atmosphere the potential growth of bacteria, algae and sludge is always present.
For example. Most houses used to have a cold water storage tank. Some still might but thay have been phased out for a long time now. If anyone looked into the storage tank they would not be drinking the water. Only, usually the main kitchen tap, was classified as drinking water.
I remember one household only became convince not to drink it when a dead pigeon was found in theirs.
Caravan systems are open to the atmosphere, even worse possibly, is that every time the system is drained it remains damp and that’s the breeding ground in my opinion.
Also. Lead at one time was considered safe for drinking water.
I feel sure those who drink the water will be fine for years to come, but we will not be doing so. And it is so easy not to need to.
Ourlast house had a combi, but like this house I fitted a water softener so having drinking taps throughout the house would have been extraordinarily complex. so we have just the one in the kitchen and one outside for the bird and hedgehog (plus dogs) drinking features. If anyone wants a drink by the bedside they take a bottle with them.My 1970's house also had that system until I updated the heating and water supply about 5 years ago.
It will no doubt take many years before 'all mains' will be the norm but most modern buildings will be OK. I have seen some discussing examples of uncovered galvanized tanks in the past. Modern plastic tanks with close fitting covers and in less dusty lofts will be fine.
Originally mine just has a small tank above the hot water cylinder. But I updated that to a larger loft tank raised up into the peak in order to get an improved shower head. Then moved to a pumped power shower system. We are now on to a Combi which gives a great space saving.
We are now able to drink water from any tap to our hearts content. But we still use the kitchen tap as everyone else does. 🙂
If I remember correctly, storing water in the property was considered a good thing many many years ago because it gave everyone a reserve if needed.
