This is complicated so bear with me.I have an onboard water tank that runs via a wall switch,ie when the external water runs out I flick the switch on the wall to internal.The onboard water tank froze solid during the big freeze and the onboard pump cracked so I replaced it.What happens now is when you run a tap on external the flow is poor because half off the flow is going into the on board tank,when the on board tank fills up I flick the switch back to internal and the system works fine.Any ideas of what is wrong?
