Waze and Android auto
5,048
Just found these apps, are they any good?
Your choice, but I have not enjoyed using Waze as we have found out very recently. We had to revert back to the good old TomTom. Waze gets you to the destination, but on occasions by the longest possible route. I think that our inbuilt car Satnav is better than Waze.
Sam Vimes
2,420
1,936
Waze and Android Auto are two different things.
Waze is a Sat Nav program that requires an internet connection and can chew through your data allowance by all accounts.
Android Auto is an app for your phone that allows it to connect to a car screen that's compatible with it or a separate stand alone screen. You can then run compatible apps on the car screen. Waze being one, Tomtogo another. Plus play music, make and receive calls and messages and other things.
5,048
Android Auto is an app for your phone that allows it to connect to a car screen that's compatible with it or a separate stand alone screen. You can then run compatible apps on the car screen. Waze being one, TomTom Go another. Plus play music, make and receive calls and messages and other things.
Surely you use Waze though Android Auto so still use loads of data? Also playing music unless already downloaded, making calls etc all uses data on the phone.
8,770
Doesn’t Android Auto run Google maps from your phone. My Apple CarPlay allows me to run Apple Maps and Google Maps plus all the other junk on my phone if I feel the need.
Sep 26, 2018
721
276
11,135
A couple of years back we went to the Caravan show at the NEC, and knowing that the roads around the M42/NEC were in uproar, I decided it was an ideal time to try Google Maps and Waze against each other, using Google Maps from our hotel to the NEC and Waze back. After the trial I was very keen to move back to the in-built car satnav! Both the Android apps failed in similar respects - in that instructions and screen indications were VERY LATE. In the Waze case, the directions didn't pop up until I was PAST the off slip.
Obviously, the immediate road layout is up to date with both apps, but I found them dangerous in those circumstances. The built in car system is SOOO Much better!
Sam Vimes
2,420
1,936
Android Auto (Carplay for Apple) is just an app that allows a connection from your phone to your Android Screen. The Screen is just an extension of your phone. Basically any Android Apps you start on the screen are running on your phone. So any of those apps that need data will get it through your phone.
Waze doesn't need Android Auto - you can just run it on your phone.
Making calls through Android Auto just uses your phones call plan most of which have unlimited calls and texts.
5,048
I had forgotten about that aspect as no fun being told to turn when you are right on top of the turn with a car following. Rather than brake suddenly I prefer to carry on to the next intersection.
As far as I am aware TomTom Go, Waze, Google maps etc do not require Android Auto to operate, but they all use data whether used on the phone or through Android Auto. Your post #6 seemed to indicate that if Android Auto, data was not used?
3,363
I've not found that Waze uses unreasonable amounts of data - I only have 5Gb/month on my phone and never get near the limit
Sam Vimes
2,420
1,936
Tomtomgo and Google Maps can work off line. Tomtomgo stores maps of the UK or other country on your phone. Google maps can store off line a small area which would then need to be update..I.e downloaded... if you move out of the area.
I'm not very familiar with Waze but believe it needs a connection most of the time.
I don't think my previous post 6, stated that if you use Android Auto data isn't used. Regardless Android Auto itself doesn't need on line data, it's the apps that are running that do.
3,363
Waze needs an internet connection to get a route started but once you're on the move and got a signal it copes with loss of signal.
I use Waze most days and certainly didn't suffer data restriction on a 2000 mile roadtrip, all done under Waze navigation.
