- Feb 13, 2024
- 1,244
- 796
- 1,435
Your choice, but I have not enjoyed using Waze as we have found out very recently. We had to revert back to the good old TomTom. Waze gets you to the destination, but on occasions by the longest possible route. I think that our inbuilt car Satnav is better than Waze.Just found these apps, are they any good?
Surely you use Waze though Android Auto so still use loads of data? Also playing music unless already downloaded, making calls etc all uses data on the phone.Waze and Android Auto are two different things.
Waze is a Sat Nav program that requires an internet connection and can chew through your data allowance by all accounts.
Android Auto is an app for your phone that allows it to connect to a car screen that's compatible with it or a separate stand alone screen. You can then run compatible apps on the car screen. Waze being one, TomTom Go another. Plus play music, make and receive calls and messages and other things.
Doesn’t Android Auto run Google maps from your phone. My Apple CarPlay allows me to run Apple Maps and Google Maps plus all the other junk on my phone if I feel the need.Waze and Android Auto are two different things.
Android Auto is an app for your phone that allows it to connect to a car screen that's compatible with it or a separate stand alone screen. You can then run compatible apps on the car screen. Waze being one, Tomtogo another. Plus play music, make and receive calls and messages and other things.
Android Auto (Carplay for Apple) is just an app that allows a connection from your phone to your Android Screen. The Screen is just an extension of your phone. Basically any Android Apps you start on the screen are running on your phone. So any of those apps that need data will get it through your phone.Surely you use Waze though Android Auto so still use loads of data? Also playing music unless already downloaded, making calls etc all uses data on the phone.
I had forgotten about that aspect as no fun being told to turn when you are right on top of the turn with a car following. Rather than brake suddenly I prefer to carry on to the next intersection.Both the Android apps failed in similar respects - in that instructions and screen indications were VERY LATE. In the Waze case, the directions didn't pop up until I was PAST the off slip.
As far as I am aware TomTom Go, Waze, Google maps etc do not require Android Auto to operate, but they all use data whether used on the phone or through Android Auto. Your post #6 seemed to indicate that if Android Auto, data was not used?Android Auto (Carplay for Apple) is just an app that allows a connection from your phone to your Android Screen. The Screen is just an extension of your phone. Basically any Android Apps you start on the screen are running on your phone. So any of those apps that need data will get it through your phone.
Waze doesn't need Android Auto - you can just run it on your phone.
Making calls through Android Auto just uses your phones call plan most of which have unlimited calls and texts.
I've not found that Waze uses unreasonable amounts of data - I only have 5Gb/month on my phone and never get near the limitWaze and Android Auto are two different things.
Tomtomgo and Google Maps can work off line. Tomtomgo stores maps of the UK or other country on your phone. Google maps can store off line a small area which would then need to be update..I.e downloaded... if you move out of the area.I had forgotten about that aspect as no fun being told to turn when you are right on top of the turn with a car following. Rather than brake suddenly I prefer to carry on to the next intersection.
That would depend on how much you use it I guess.I've not found that Waze uses unreasonable amounts of data - I only have 5Gb/month on my phone and never get near the limit
Waze needs an internet connection to get a route started but once you're on the move and got a signal it copes with loss of signal.Tomtomgo and Google Maps can work off line. Tomtomgo stores maps of the UK or other country on your phone. Google maps can store off line a small area which would then need to be update..I.e downloaded... if you move out of the area.
I'm not very familiar with Waze but believe it needs a connection most of the time.
I don't think my previous post 6, stated that if you use Android Auto data isn't used. Regardless Android Auto itself doesn't need on line data, it's the apps that are running that do.
That is true, but surely you still need to download the data for them to work offline?Tomtomgo and Google Maps can work off line.
Which you can do on your home internet connection, avoiding your mobile data use.That is true, but surely you still need to download the data for them to work offline?
For Tomtomgo once the maps are downloaded to your phone, which as Tobes states can be done at home, you don't need to do it again... except for map updates.That is true, but surely you still need to download the data for them to work offline?
This is a caravan forum, so I would expect that you are out and about and no home wifi available.Which you can do on your home internet connection, avoiding your mobile data use.
But you only need to do it once at home if you use something like Tomtomgo. Then you can use it for as long as you like without a connection.This is a caravan forum, so I would expect that you are out and about and no home wifi available.![]()
Many caravanners have a WIFI setup in the caravan, using a MIFI router or similar.This is a caravan forum, so I would expect that you are out and about and no home wifi available.![]()
Doubt if it is many? probably a few have wifi set up, but they would still be downloading data as they are using a sim card?Many caravanners have a WIFI setup in the caravan, using a MIFI router or similar.
If their setup can handle streaming films, etc the extra data for satnav will be small by comparison.Doubt if it is many? probably a few have wifi set up, but they would still be downloading data as they are using a sim card?
