- Mar 14, 2005
- 10,137
- 940
- 40,935
I think most of us realise that the MIRO may differ between the type approval and when the caravan was manufactured however the difference may be a couple of kg an no weigh bridge will pick up that difference as it could be over or under. more than likely it will be under going by the standard of some caravans. Either way as pointed out the MIRO figure is a good starting point when loading your trailer or caravan.![]()
I don't know how big typically the variation can be between a published MIRO and the actual weight of a caravan, but for cars differences of up to 150kg can be expected, and that is easily within weighbridge accuracy. For caravans it will probably be less, but that doesn't mean that it's necessarily negligible.
It only needs a manufacturer to add, say, a motor mover or air conditioning as a standard fitment during the course of a model run. He won't resubmit the caravan for type approval just because of such a specification change so the MIRO will remain the same even though features have been added.
