Hi, i just fitted my new whale aqua source to my bailey ranger 550/6, it clicked into place ok but when i turned the mains water on, the water was leaking a lot out of the socket, any help would be appreciated, thanks
Thanks grimbo, will check that seal.Hi Cliff,
Check the rubber "O" ring to ensure it is seated correctly or for any damage such as a small nick etc...
Not much else to go wrong with it apart from this seal.
Good luck hope this helps.
thanks for the info, do you have the website address?if you go to touring and tenting site the whale representative actually has a section and deals with problems,sent my pump back through him to be fixed at factory probably send you some 'O'rings
