- Nov 22, 2012
- 5
- 0
- 0
I've recently bought a 2004 Adria Altea 502DK and before now I've never felt the need to use the Whale water pump. So I've sterilised it using a liquid steriliser. However, when I plugged the Whale pump into the connection on the caravan there was a lot of play and water came out around the pump conection. After some fettling I managed to get an acceptable seal for a few seconds but it then started to leak again. I've turned the 2 locking systems at the plug and there is still play unless I push against the plug. The Caravan came without a manual and although I got a pdf of a manual it doesn't have this type of exterior pump.
Am I missing something or is it the 'o' ring that needs replacing?
