Whale Smartflow Pump
Hi John, apologies for not replying earlier we've had problems with Internet signal. I did see the websites on Google and purchased what I thought were the right ones but although the outer diameter was OK the actual diameter of 0 rings was not the same fitted to outlet of pump for some reason the 0 rings are thicker if you can see what I mean.
You would expect it to be correct if it says it is for the job. Perhaps there has been a specification change at some time.
